91 Vic Odometer not working
    OK
    On my 91 Vic Wagon, the speedometer works fine, but the odometer doesn't work.
    So, do we have an electronic speedo and mechanical odo?
    I've done a search for the problem, but haven't found anything specific.
    Any pointers on what might be the cause and fix?
    Thanks!
    Whoops, should this be in the interior section? Apologies if this is in the wrong section.
    T.A. Malpass 83 LTD Crown Victoria P43
    nope they're both mechanical, your odo is broke
    '88 Colony Park, white with wood grain contact paper, K code axle, hose pliers on heater hoses, factory duals, big plans in the future...
    '83 Toyota 4x4, 31x10.50 15, could use a new carb, custom humidifying holes in the roof, mud based paint...
      91 vic speedo is electronic
      the odometer gears strip out
        Electronic speedos started in 1990.
        Seems like a very common problem.
          It wasn't important enough for me to drop $25 a gear. I probably would have broke the speedometer changing them, too.
            Thanks for the clarification!!!!
            Gives me an excuse to drop a 140 speedo in.
              I must say that having the 140 speedo gives the car a complete different feel!...well at least a look. lol
                whoops my bad
                  No, the speedometer is electric, and a gear driven by the speedo turns the odometer, they break very often, even the aeros had the same problem. Our odometer only works when it feels like it. I'm not sure if Ford sells a repair kit or not. Only other bet is a junkyard car that still has a working odometer. But that probably won't last that long.
                    my odometer stopped,and then the trip did. dont even try to get them at the junkyard,they fall apart when you touch them. cheap brittle plastic
                    [URL="http://www.cardomain.com/ride/3358314"]
                      mine is broke 2 just never fixed it
                      Stock 91 Merc GM GS 5.0L EFI, AOD, 2.73 Open diff
                      Current Best 1/4 Mile 17.175 = 165 RWHP 190 Engine HP
                      http://www.supermotors.net/vehicles/registry/15193
                        all 90-91's do it
