BUILD UP IDEA-COMMENTS PLEASE
    explorer engine has an oil cooler bolted to the block.....no room to make it fit in the panther....steering box is in the way
    they dont have thermactor passages in the heads, but nothing stops you from bolting the tubes on to make it appear its all there
      I'd slap a port matched HO intake on it and SWEAR it was a 5slow
      1987 MGM 126K 2" True Duel flowmaster 40's 3" tipped exhuast, Tinted 20% all way round, individual bank A/F guages, tach.
        Y'know Scott, come to think of it, those numbers I pulled last year was with a COMPLETELY clogged engine tube on the back of the engine, and the usual EGR/thermactor codes.
        So that just might work.
          If they just do a visual and a tailpipe test losing the smog stuff won't affect anything. I passed easily once I got my tweecer installed and corrected the maf and injectors. So, if it's a stock exploder motor with the mark7 ecu and 19's it'll be fine with just the EGR and cats to pass the sniffer. Most places around here are a joke with the visual....
