Do I need to adjust the valve lifters or are they automatic?
Another daft question from a beginner with a 1984 302ci Grand Marquis. As above, do I need to adjust my tappets (lifters) at regular intervals or are they self adjusting?
Thanks
1984 Mercury Grand Marquis 5.0 LS on propane. All season daily driver since 2008
Usually attention to valve lash on these cars is required only when swapping heads or installing new rocker arms. In that case, with stock pedestal rockers anyway, you'll want to swap pushrods and/or add rocker shims as necessary to get about 3/4 turn from "zero lash" to torqued.
Do you seem to be experiencing lifter noise?
Most likely. Is you Canadian '84 a CFI or 2V carb?
I is Canadian but I ain't neither CFI nor 2V carb, I is propane regulated which makes things interesting cos I ain't heard of any other propane Panthers!
