Idk what happen but than i let it warm up for like 30sec than it was fine. The next day I went out to it and didnt put it into any gear but turn the wheel all the way than it stalled again. So I let it warm up no problems... than after that it did same in reverse later on when i let it sat for like 12 hrs so any idea what the problem is?
So I went to my car the other day and I started it up and put it in d and it stalled
The iac was new about a year ago. I didn't touch the idle screw but my mechanic might have. How do I check if it's I'm right spot?sigpic1986 Crown Victoria 302 Cold Air,Mac Shorty headers, Full Dual Exhaust with Super Forty Flows, Wagon Suspension with a Full Sound System Replacement 1/4 time 17.486 @ 77.43mph
Give it a few seconds for the idle to stabilize. Mine wants a good 30 seconds for the idle to come down to where it belongs. Usually its idled up high as soon as you start the car anyway, and its not real great to drop it in gear at a high idle.86 Lincoln Town Car (Galactica).
Mine does this occasionally after I disconnect the battery and it's relearning its idle. It always thinks the IAC needs to be open less than it does and stalls the first few times. It figures it out eventually.
Did you disconnect the battery recently?Originally posted by gadget73There is nothing more permanent than a temporary fix.
