well I have an 88 ltd crown victoria and I was going to change the headers with some stock 88 mustang gt but then I seen the oxygen sensor. But the mustang's headers don't have an opening to putthe sensor in so can I still put the headers on without putting back the sensor or will it affect the way the car drives and what do I need to install the headers in? Thanks alot
Oxygen sensor on headers
Eliminating O2 sensors on an injected vehicle is a Very Bad Idea (I am assuming here that your vehicle is a 5.0 SEFI car), as they're the ECM's "ears" for determining whether the air/fuel ration is correct.
You have two usual options:
One, if you modify your existing exhaust pipes to fit the larger ball-style joint on the Mustang headers, you can jut buy some O2 bungs and weld them to your pipes as close to the header as practicable.
Two, get a Mustang-style H pipe - it will have O2 bungs positioned a little way down the pipe.
Either way, you'll probably want to get new sensors with longer pigtails on them. As I recall, your original ones won't quite reach.Last edited by 1987cp; 09-06-2009, 02:39 AM.2012 Mazda5 Touring | Finally working on the LTD again!
yep, Mark VII sensors should be the long wire versions that you'll need. Any exhaust shop can add the bungs for a nominal fee if you don't have a welder.86 Lincoln Town Car (Galactica).
I've actually seen both listed for Mark VII's as well, never looked up the stock replacement sensor. I actually screwed up when I bought mine. I got them for the 88 Mark the motor came from. The plugs are of course different on the 86. Handily the short harness between the main ECM harness and the O2 sensor harness is the same, so I got one from an 88, and now my car takes 88 sensors.86 Lincoln Town Car (Galactica).
So I can use mark sensors? Which year of sensors Im I going to need? Is there diffrent versions of them? Also I was going to insert the bungs too but look like there's no room for them on the mustang headers. Is there a certain place the o2 sensor should be? Does it have to be before or after the catalyst converter? Sorry I don't know about o2 sensors thanks for all your help!!!
90 town car headers are a direct fit......not quite as good as mustang headers, but better than cast iron logs
The bung is easiest to install below the header, on the pipe between the collector and the catalytic converter.
88 Mark VII sensors will work for an 88 Vic, or use the long wire sensors for the 88 Vic. Same thing, just the wires are longer. Most Ford oxygen sensors are identical, other than the length of the wires and the connector at the end.86 Lincoln Town Car (Galactica).
