I had a 90 stang with a c6. It was fun but it also had a hurst quarter stick to slap it around.
Is a 351 worth it?
1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
Now you got me thinking. Maybe I could find someone that wants to use the c6 for racing (I'm told they are very durable) and I could take there T5 off their hands. My sister's boyfriend has a built mustang (I think he races it) so I wonder if he would know someone. I'll have to give her a call. Also I was going to see if he knew someone with a set of headers for cheap. The stock headers off a 5.0L Mustang are what I'm looking for right? As for the H-pipe, I'm guessing the stock h-pipe off a mustang won't work or maybe I could widen the H a bit since the 351 will be slightly wider since it is taller right? Any other parts that guys racing mustangs might be getting rid of that I might want for this?'85 Mercury Grand Marquis
only MSD multi-spark so far but hopefully a 351 on the way.
I seem to recall P72ford saying something about the H-pipe on a whale being wider. If that's true, perhaps you could get one cheap and have the upper ends hacked off and have larger flanges (ends bells whatever their called) that will match up to the headers welded on?Former panther owner
1981 CV 351 4bbl
1991 CV 302 EFI
The h-pipe is the same the headers are different.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
Question on this . . would it be just as easy to maybe go 331 or 347 on the 302 block as opposed to going with a 351?
I know this all depends on how tame vs wild he wants the engine to be, and I don't know how well the oil-control-issues of 347 builds have been solved - but might not the missing 4 (or 20) cubic inches be compensated for by a slighty smaller, lighter block?
Just tossing the idea out there.. he did say fun but not anything extreme, after all.
Of course, I'm a cheap SOB, so I'd probably go with whatever I had more stuff on hand for, and put together without busting my budget.
I am also, admittedly a fan of the precision of SEFI, so I'd go with that, within the confines of the "what I have, and how much money I have" rules...1987 Ford LTD Crown Victoria 2-door Coupe - perpetually "sort of" for sale...
Black with Red cloth (velour?) interior.
Purchased on 10/10/2008, with only 70,386 original miles, and only ONE previous owner.
Reader's Ride post, First pic with "new" rims, Other pics with "new" rims
Originally posted by King_V View PostQuestion on this . . would it be just as easy to maybe go 331 or 347 on the 302 block as opposed to going with a 351?
I am also, admittedly a fan of the precision of SEFI, so I'd go with that, within the confines of the "what I have, and how much money I have" rules...'85 Mercury Grand Marquis
Originally posted by andymac0035 View PostI seem to recall P72ford saying something about the H-pipe on a whale being wider. If that's true, perhaps you could get one cheap and have the upper ends hacked off and have larger flanges (ends bells whatever their called) that will match up to the headers welded on?Originally posted by Pesty351 View PostThe h-pipe is the same the headers are different.
I ended up sectioning the h to make it fit on the burnout box.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
He was talking between a 351 and a 302 width wise.1984 CV tudor 351W, 4bbl, 5-speed best time in the 1/8 8.39 at 80 with 1.80 60ft time.
So what I want to find are some shorty headers and then a mustang h-pipe off a 5L.
Thanks'85 Mercury Grand Marquis
You could drop a mild 351 in for a lot less than you'd pay for a 347 stroker kit and machine work. Plus, you'd have a motor you can make 700 hp with and not have to worry about the block splitting in half where you're talking 500ish out of a 302 block. You could recycle a 302 intake for the 347, but chances are you'd want something much better, so theres no real savings there vs a 351 intake. Oil pans are also no big deal, and its gonna need exhaust either way so truthfully there is very little in the way of reusable parts from a stock 302 on a 347, even if it does physically bolt up.86 Lincoln Town Car (Galactica).
Since you mentioned oil pans that reminds me of a question. Someone mentioned that when they put a 351 from an e350 in their panther, they needed to change the oil pan and water pump. Will I need to do that with this engine coming from a F-250. If the truck oil pan won't fit my car, do I have to find a panther with a 351 and get the oil pan from that or will my 302 oil pan work? Same question about the waterpump.'85 Mercury Grand Marquis
351 Panther oil pan only, AFAIK. The 5.0 one won't work. A mustang 351 swap pan is the exact same shape if you have trouble finding a crown vic pan.
truck pans are different. Need the panther pan, which is what the 351 swap Fox Mustang pan actually is. You can get them brandy new. Water pump will just be a standard replacement pump for a Vic. I think the truck ones might spin backwards, or have different pulley spacing or something. Would be a good excuse to pull the timing cover and check or replace the timing chain anyway.86 Lincoln Town Car (Galactica).
