It took forever to find the freakin pcv valve but I eventually found it. Once you know what and where it is, its pretty simple. I'm going to do a picture write up to make things easier for the next guy. But for now, the simplest way I would explain it for my EFI is...
1. Stand in front of passenger side tire and look into the bay. (from side of car)
2. Stick your hand under the intake manifold and find the big hose the runs along the underside of the big, steel, silver, intake manifold. This hose is connected to the front of the manifold and runs along the underside of the manifold to the back where it goes down and plugs into downward pointing hole.(hole points toward the ground)
3. The hose is ribbed so I was able to just pull it out.
So basically, follow the semi biggish hose that runs along the underside of the passenger side of the intake manifold, from front to back. The back side is the side (closer to firewall) you want to unplug and pour the seafoam.
I put 2/3s of it in the pcv and the rest in the gas tank. It sounded like it was going to cut out when I was pouring it down the pcv hose but it didnt. I turned the car off and let it sit for 20 min and took a drive.
There was a good amount of smoke and I'm not sure if its just me but the car felt like it pulled smoother and sounds a little bit louder. I still have it in my gas tank so after I finish the tank, I'll change the ignition stuff.
