Hi!
Bought my car a few months ago with little idea of its maintenance history, so for fun, learning, and being a responsible car owner, I've been doing all the regular maintenance that I can think of so that I personally know when it was last taken care of.
After a friend ran into poor fuel economy with a bad O2 sensor and was advised to also clean out his fuel injectors, I figure, why not do mine as well?
Now, it was pointed out to me that there's a capped valve that leads into the fuel rails, and I can pump a fuel injector cleaner into there and idle the engine for a few minutes?
Less effectively, I can add the same cleaner to the gas...
Or finally, courtesy of a site gadget pointed out to me, just remove and soak all the injectors?
What do you advise? If the injectors come out easily without making a mess, that looks like the most effective cleaning possible, and I prefer the idea of cleaning them out of the car, instead of idling the engine with something other than gasoline trying to burn in it.
Is it as easy a job as it looks?
