Ok heres the deal Ive been getting horrible mileage which I attributed to the size of the car. Yesterday I had the wife start the car while I was behind it Because I wanted to hear my new dual exhaust again (it sounds like a grown up mustang). When she started it up I smelled big time unburnt fuel. So I figgered maybe o2 sensors. Well today before I ordered them I figgered Id pull codes heres what i got for koeo fast blinky then 34,34,1?,34. I know the 34 is this:
34) Insufficient EGR flow/Excessive exhaust back pressure; or EVP voltage above closed limit(SONIC)/PFE sensor voltage high or out of range. (O)(R)(C)
Whats the most common way to approach this code? Like Ive said in the past its been a long time since Ive dealt with ford drivability. I would expect a rich condition to make the o2s register a code?
I do know the egr functions when vacuum is applied and it holds vacuum, all the egr passages are clean because about a month ago i took the upper intake off,cleaned everything real good and replaced all vac lines ect.
