Ah, okay, got it. Thanks guys!
What sort of thermostat do I need?
Originally posted by 1987cp View Post86Vicky hates Failsafes because he feels they can cause premature engine wear if they stick open and the car runs too cold for a long time. I always notice my AutoGage temp gage from time to time while driving, so I'd know immediately if my Failsafe had failed.
Originally posted by PushnFords View PostI've actually had the best luck with the cheap thermostats. I've had two trucks that the previous owners put $12 "Failsafe" thermostats in and they both went bad. Funny thing was when the one stuck open the truck overheated because it couldn't cool the water fast enough. I put a thin layer on both sides of the gasket to seal any imperfections and then put it together with some antisieze on the bolts.
i've run a 180 degree thermostat in the town car since the 90's.......a 160 i would not use
Originally posted by gadget73 View PostWhat you're seeing is a pipe threaded bung for a temperature sensor or a thermostatically controlled vacuum valve on a carb car.2012 Mazda5 Touring | Finally working on the LTD again!
I like the housings that have the threaded hole, not only for the additional sensor location, but they also tend to be cast iron instead of aluminum so harder to crack.. which i've done my fair share of times with the aluminum ones. Some parts places don't show that one when you look them up for our cars, but they show up under stuff like early 70's bronco's.
