The boxes have air shocks, so even if the thing completely dies the car won't drag on the ground like the round models do. Its a cool feature though, throw a bunch of stuff in the trunk, compressor comes on, and you're right back to normal ride height.
if the rubber mount bushings are falling apart, it will make more noise. I think arnott or americanairsuspension sells new rubber mount bushings, or if you're clever you can probably come up with something from a decently stocked hardware store. I've made stuff like that before out of a couple different size wire grommets stacked together.
