we just replaced the head gaskets on my buddy 81 5.0 and when we went to put the gaskets it closed off the the front water jackets on both sides except for a small hole. is this correct. the head gaskets are made by engine tech and it has front labled on the gaskets so the installer knows which way to go. thanks 84 merc
head gasket ?
head gasket ?
1984 mercury grand marquis ls rebuilt 306 flat top pistons with factory cfi and lincoln headers with single glasspack dual snorkle air cleaner. Gloss black paint with slick top coversion.
1986 mercury grand marquis colony park 5.0 sefi dual exhuast thrush turbos with h pipe and turbinesTags: None
Its only one gasket for left and right, but it only goes on there one way. If you put it so the 'front' marking is in back, it blocks a coolant passage and causes problems. The small hole does sound familiar, though honestly its been a couple years since I actually looked at a 302 HG.86 Lincoln Town Car (Galactica).
can't say I know the answer off hand, but maybe this thread helps?
thank you very much. was a lil confused.:smirk:1984 mercury grand marquis ls rebuilt 306 flat top pistons with factory cfi and lincoln headers with single glasspack dual snorkle air cleaner. Gloss black paint with slick top coversion.
