Anyone ever have a grinding Noise come form the car at around 30-35mph upon acceleration and then it goes away.. Sounds kinda like a power saw.. I have no idea WTF it is, the car is running fine tho so I kinda just ignore it
Grinding Noise???
are you able to narrow the noise down? like is iit comming from the front or back? it dont sound promising, if you say it only happens on accel.
If you ignore it long enough, whatever part thats causing the noise will fall out on the ground, then you'll know what happened.
Ever check the U joints? When they get dry they make ugly noises.86 Lincoln Town Car (Galactica).
U-joints? again?lol. where do you get your parts mang? makes sure you get greasable ones this time.
IDK I think its the drive shaft itself.. Because when it fell out the first time it got pretty banged up so I took it to my mechanic cus I couldn't do it and he hammered the fucker out and did all this shit to save it and put new u joints in but he forgot or didn't even realize to put a new tail shaft seal in my trans and thats been leaking so god knows what he fucked up I probly need a ned drive shaft cus it just plainly F'd
