Persistent Code 21 ECT Sensor Issue
    i have had this code for awhile now and its still will not go away. i have replaced the cooling system parts recently have new hoses new rad new rad cap new thermostat, new water pump and new fan clutch. problem is at operating temp code 21 still is on. now just did some tests i have replaced the ect sensor and this code is still present. i have a full rad of coolant and had the car running at op temp i noticed something though the upper rad hose gets hot but it doesnt feel pressurized i can press the hose in also at op temp the lower rad hose isnt hot at all. did my new rad cap fail, is there a block in the new rad i dont know. i ran the test on the ect sensor on a scale of 200k which is 200,000 ohms i checked resistence between the two probes on the sensor and got both with engine running and engine off 03.4 ohms what does this mean. i really would like to solve this code 21 cause its fucking up my fuel mixture badly.
    after the car was ran for awhile at operating temp i shut the car off and loosened the rad cap no pressure was released as no coolant overflowed out of it. this is really bugging me.
      code is gone for now. must have had air in the system and my overflow bottle was empty filled it up now. will recheck codes tommorow.
        If its not making pressure, either there is air in there or its not warming up.
          air
            Originally posted by 1990LTD View Post
            air
            it had to be air since i had no coolant in my overflow bottle for months so it probably sucked air instead seems fine now.
