I have been having a long term issue with pinging/breaking up under load with the wagon. If I used low-test it would clatter, lose power and blow smoke out the pipes when I hit the gas hard.
Eventually it even pinged slightly with hi-test on hot days. The timeing is set to stock.
I started to work on this problem maybe a month ago. I pulled the plugs and put a scope in the cylinders and found the pistons covered in carbon and the plugs in good shape.
I used "Run-rite" cleaner thru the throttle body and started useing their fuel additive product. A few days before Scottfest I pulled the plugs, inserted about an oz. of AC Delco top engine cleaner in each cylinder, put the plugs back and let it sit overnight.
Next day removed the plugs, spun the motor over and small chunks of carbon spit out along with the cleaner fluid. Put in new plugs, wires, cap, rotor. Gave it another throttle body treatment and changed the oil/filter as I was concerned that the top engine cleaner might have diluted the oil. I have been useing the fuel tank additive right along for about 5 tanks.
Went to Scottfest and returned, about 600 miles all told. Last Thursday I borrowed the camera again, pulled the plugs, they were nice looking but with a carbonny coating on the outer ring. I ran a compression check. It came out great, had a range of 132 to 140 lbs.
When I looked at the pistons with the camera, easily 75% of the carbon was gone. The remaining crust is primarily a circle around the outer edge of each piston. There are in addition, occasional adhesions scattered on the piston tops.
I can not attribute the carbon reduction to any specific treatment. I wonder if I am wasteing my money on the fuel additives? Maybe the soak and TB treatments are the solution? Anyone gone through this process? Any suggestions? I have not tried low octane gas as yet as there is still significant carbon in place. Wish I could get a look at the valves but I can not get the camera to look up.
I am hopeing that after the carbon is eliminated I can boost the timeing a bit as the exhaust is a little bit more open than stock.
Jay
Jay
