removal of smog pump and associated garbage is pretty easy... plugging all the holes (cats - easy, heads - not so much to make it clean) can be tricky. to pass emissions, drive around for 30+ minutes before hand to make sure the cats are good and warmed up and you should pass no problem.
smog removal
Yeah the cats...you just need to cut and crimp, I know that, but the heads, i am just worried that I don't do it the right way."To Find yourself, you must first lose yourself"
-1973 Volkswagen Bus Westy
-1986 Honda Magna 700cc
-2011 Subaru Outback
Originally posted by sly View Postyes. 56" belt (K060560 for 6-rib setups). Run it with the belt on the top of the tensioner.-Phil
Originally posted by Brown_Muscle View PostIs this the same as the 351 would use for smog delete?
