'91 with a drinking problem
    She stays out late at night. Comes home smelling like used oil. I think she's been sleeping with some bad Dodges. I'm worried about her.
    This car baffles me. Runs fine.
    Drinks antifreeze, no puddles on the floor or white in the oil. Drops about 4 inches every 2-3 weeks.
    Drinks oil, no puddles on the floor. I had to add over two quarts today. One of those quarts was my bottle of Lucas Oil Treatment. Trying that to see if it helps. Takes about a quart every 700-1000 miles.
    Once a month, it will spill most of its power steering fluid on the garage floor. No pattern to it. Nothing different in driving routine or temperatures. It just dumps the fluid. Mechanic can't even see a leak.
    I'm open to any ideas for all of those problems.
    I know what the power steering fluid is caused be. Pisses me off too. If you turn the wheel with the engine off it will burst out of the cap.
      Pressure test the cooling system. Sounds like a pinhole leak somewhere. As for the oil loss, how long has it been since you put a new PCV valve/screen/grommet in? It might be stuck and sucking oil right out of the crankcase. I'd also degrease the engine really well and see if it shows leaks anywhere. The back of the intake manifold is a common leak spot. You might also simply be burning it if the motor is old and beat.
        Re: '91 with a drinking problem
        Aside from the power steering fluid my car does the same thing, I just blamed it on my dumbassery.
        "If I owned Texas and Hell, I would rent Texas and live in Hell."
        -Gen. Philip Henry Sheridan
          I found that one out the hard way too!!
            Yea, my brothers 90s Vic uses oil, no leaking and no smoking, is the PCV the likely culprit? ANy other ideas?
            2000 Grand Marquis LS
            Mercury Owners Group member
              Maybe not the most likely, but its a cheap possibility and nobody changes those things anyway. Just make sure to do the valve, grommet and screen all at once. The parts can be had from Napa, and probably most places if you can get them to understand wtf you're talking about. The screen is sometimes called the crank ventilation filter. The PCV valve is important because without it, the crankcase will build pressure and actually force oil out of the engine either past the seals or past the piston rings or valve seals into the cylinder. The screen under the PCv valve often gets crudded up, making it ineffective, and that rubber grommet is usually hard as a rock and doesn't seal, so pretty much the whole system becomes worthless.
