spark plug gap
    spark plug gap
    does anybody know what the correct gap for spark plug is? im kinda stranded here and couldnt find it here on the threads
    -1973 Volkswagen Bus Westy
    -1986 Honda Magna 700cc
    -2011 Subaru Outback
    plug gap
    my chilton manual lists the spark plug gap for ford v-8 1979 to 1988 as .50
    or fifty thousandths.
      its on the emissions label under the hood along with the proper spark plug type, ignition timing, and vacuum routing.
        I've seen everything listed from .044 to .054 for the 302. so somewhere between 45 and 50 thousandths should get it.
          .0048-.0052 Like mentioned above, check on the VECI sticker on your fan shroud. It should be mentioned there.
