Be aware: The exhaust shops are becoming dicks. The local exhaust shop here which is the cheapest option for duals, or regular patchwork stuff has a sign up that says they'll charge you $XX per catalytic converter if you want to keep the old ones. You will want to check with the shop first, if they do that sort of thing you may need to cut the old cats off then drive it to the shop huffing fumes so you can get your money out of the cats.
Catalytic Converters
What do scrap cats go for these days?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by jaywish View PostWhat do scrap cats go for these days?1985 LTD Crown Victoria - Currently restoring after she caught fire! CFI to SEFI to Carb swap, all custom wiring, Duraspark 2 ignition, Motorcraft 2100 Carb, slicktop, Shorty headers dumped before rear axle, 140 Speedo, 3G alt, And currently building an engine for her.
It is hard cash03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
depends on your location, and the scrapper you take them to. I only managed $20 for all the cats off my 88 when I put the magnaflows on.
Originally posted by sxcpotatoes View PostBe aware: The exhaust shops are becoming dicks. The local exhaust shop here which is the cheapest option for duals, or regular patchwork stuff has a sign up that says they'll charge you $XX per catalytic converter if you want to keep the old ones. You will want to check with the shop first, if they do that sort of thing you may need to cut the old cats off then drive it to the shop huffing fumes so you can get your money out of the cats.
fmansfield, I'd be happy as hell with $80, that's like 1/3 the price of my new ones, I'll look around and read reviews to find the best place to take all my junk.
Oh yeah, and I grabbed those lincoln logs today they gave me a hell of a time though and I got sunburn all over my back but it was fun. Time at the junkyard is always fun for me.
