The Explorer upper intake does not have a provision for the Air Temp Sensor. Were do you put it?
Explorer Intake Air Temp sensor
There should be a boss in the #5 intake runner, you have to drill and tap it.2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Some of the "newer" (99/00/01?) do not have the boss........i've got a buddy that has one like that, he just leaves it lying on the intake lol..........you can actually CAREFULLY drill the #5 runner itself but it doesnt have alot "meat" or relocate it to the inlet tubing.........Last edited by Mr.Blue; 09-05-2013, 09:52 AM.Rodney Tolleson, me at the track.....future drag box racer!
Originally posted by Grand1 View PostThe Explorer upper intake does not have a provision for the Air Temp Sensor. Were do you put it?
Its a 1988 GM....HO motor from a 1992 Mark series....got the ECM from the Mark as well.
Whats the tap size?
Not to be completely stoopid is "the boss" the EGR?
1979 Marquis creamy goodness
I *think* the tap is 3/8" NPT, but verify that. Its definitely a pipe thread whatever it is.
Another little thing that relies on that sensor is the ECM going into long term learning mode. If it doesn't see over some temperature, 120F I want to say, it won't go into learn mode.86 Lincoln Town Car (Galactica).
Originally posted by Grand1 View PostIts a 1988 GM....HO motor from a 1992 Mark series....got the ECM from the Mark as well.
Whats the tap size?
The boss is a blank spot where the sensor should be on the 5th cylinder runner. Early explorer intakes have it and later ones don't.
You can see the boss in this picture. It's the flat circle on cylinder 5. If yours has this its easy to drill, if not then drilling can be done but be very careful!
Just saw gadgets post and I think he's right on the thread and tap size. Disregard mine.
Last edited by fmansfield444; 09-05-2013, 05:19 PM.1985 LTD Crown Victoria - Currently restoring after she caught fire! CFI to SEFI to Carb swap, all custom wiring, Duraspark 2 ignition, Motorcraft 2100 Carb, slicktop, Shorty headers dumped before rear axle, 140 Speedo, 3G alt, And currently building an engine for her.
2000 Lincoln Town Car Signature Series - 165XXX, PI intake swap , 30 MPG Easy on the Highway, All options except dual exhaust. Currently looking for 2 front seats: Heated, Memory, and Light Graphite color!!
[QUOTE=fmansfield444;702955]
Once again a picture is worth a thousand words, thanks for posting this pic.
The drill bit is like a 15/64" or something really weird like that. Be sure to drill the proper hole before you tap it! Gadget is right on the 3/8" NPT. NPT sizes are weird, so make sure you're using the right tap!
Thanks for the knowledge...its actually what my mechanic is doing .....putting the finishing touches on my engine swap.
He had a hunch about that tap size Gadget confirmed.
Cant wait....pics soon, promise!
