I have a cold air (warm air) chrome intake tube and conical air filter bolted on the stock TB. I have a few questions about bolting on the HO TB.
1
I bought another 50mm TB (stock) and have a 60mm TB (HO). I didn't know the 50mm was so puny. What was Ford thinking when they put this thing on a 5.0L 302 motor? It's small, it steps down inside, it's awful!!! I know I have to put the 50mm throttle arm on the 60mm TB. Can the HO TPS and IAC be used for my application or do I have to use the non-HO parts for my GM?
2
What kind of lube should be used on the TB? Is silicone spray OK?
3
I want to use new mounting hardware. What size studs are used to bolt the TB and EGR to the upper intake? Are vise grips the best way to remove and install them?
1
2
3
