1984 Ford LTD Cv startup proplem
    the white paste was cleaned off the old location on the dizzy and new goop that came with the new TFI applied?
    next thing to check is if it's getting crank power. If you can turn the key to ON and jump the starter solenoid on the fender (jump the large lug closer to the battery to the small pin at top) and the car runs... then crank power is your issue and we're looking at an ignition switch (in the steering column - not the key hole) or a relay/wiring issue.
      Yep, i cleaned the location for the new tfi and applied the silicon that came with it.
        Does it have spark? Find that out before you go further.
          Okei so i checked again if i were getting spark after i changed the TFI Module. And i am getting spark,he Still dsn't start just cranks. I just tryed turning the distrib clockwise and he bearly started for 4-5 seconds and then died, to get him to start for theese 4-5 second i had to put the petal to the metal while starting, and then he died after 4-5 seconds..
          What is going on good fellas ?
            Could it be Bad EGR Sensor or valve ?
              Id clean the EGR valve real good, in case shes stuck and filthy with carbon. Is the fuel pump strong? Whats the psi at the schrader valve before a cold start?
                Is the distributor installed correctly? If it was removed and re-installed in the wrong position, it won't start. Find top dead center on the #1 cylinder and verify that the rotor points towards the #1 spark plug tower. If it does not, pull the distributor and re-drop it. Also verify that the plug wires are run correctly. It won't go if the firing order is mixed up.
                  i did get it running, It only starts if u floor it, (else it just cranks) and goes slowly up in RPM, once it has reach'ed high rpm it runs normaly above 1500 RPM but lower than that and it chokes. It has correct distrib position and all the spark plug wires are correct.
                  Im complitly lost..
                  Another question.. I'm gona change to carburator, And i've read that i need lokar TV cable and Bracket on my carb for the Overdrive. ( http://www.summitracing.com/int/part...4000/overview/ ) I found a Original carb of 1974 302. Does anyone know if that bracket fits that carb or only Holley and edelbrock ?
                  Many thanks- Ingvi.
                    Are you getting fuel at the carb? How is the compression of the cylinders?
                    Is there slop in the timing chain? 84 has the plastic timing gears. You can do a quick check by seeing if there's any lag between when the crank pulley turns and the distributor rotor spins.
                      are you sure the firing order is correct? it doesn't use the HO firing order.
                      should be 1-5-4-2-6-3-7-8
                        The firing order is correct, I have not checked the compression, and it is getting fuel to the Cfi system.. :/
                          the spark plugs are black and fuel smelly, and the car chokes on low rmp, and when it were on like 3-5000 rpm a black smoke came out of the exhauts.. isint he getting to much fuel ?
                          How should i fix that?
                          and how can it be getting to much fuel when nothing really happened before it ran normaly ?
