In addition to the all the other stuff that needs changing the oil filter adapter from the explorer won't work. And when it is removed, you can't just spin a filter on. F1AZ-6890-B shpould be the correct PN for the proper adapter/bung. What PITA. that is keeping me from starting the motor right now....
For those wanting to use an explorer motor...
Well, basically everything that isn't the block or heads gets changed. Intake requires some minor mods also. No big deal.
Valve Covers
Oil pan
Oil pump pickup
oil filter adapter
timing cover
balancerBuilder/Owner of Badass Panther Wagons
Originally posted by mrltdF1AZ-6890-B shpould be the correct PN Intake requires some minor mods also.
You could probably stick that intake air temp sensor in the tube between the air filter and throttle body if you extended the wiring a bit. It would probably be slightly more accurate as it would be actual airstream temp, tho it would read a bit cooler than air in the intake itself, so the fuel table would be a little skewed. Probably wouldn't be really detrimental tho.86 Lincoln Town Car (Galactica).
Also, the edges of the upper intake hit the fuel rail. Had to grind those down for it to fit. The vacuum tree will not fit either, so be ready to completely redo the vacuum system.Builder/Owner of Badass Panther Wagons
I'm currently in the process of installing a GT-40P from a 1998 Explorer into my 1989 Crown Victoria station wagon- I'm picking it up this Saturday.
Why do the valve covers not fit if the valve covers are from the same motor? Would a phenolic spacer allow the necessary clearance?
Are you using the Explorer fuel rail? Again, I don't see why they wouldn't fit unless there is a problem when you turned the upper intake 180*, assuming that is what you did to keep the stock throttle cable location.
Do you have any more details on the vacuum tree? I've redone my entire vacuum system three or four times, so far, so I'm not unfamiliar with it, but any information you could provide would be great.
Finally, I've heard you went with BBK headers and they had the necessary spark plug clearances. Do you have the part number so I can try to score a set used and not get stuck paying $300 for new FRPP headers?
Thanks in advance!!2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Oh, yeah- I guess I could have introduced myself.
Driving a 1989 Crown Victoria station wagon. I was in the process of a T5 swap (gathering parts, preparing pedal assemblies and such) when my oil pump (or something vital) decided to go on vacation.
So now, I'm also swapping a new engine. If I'm going with a new engine, might as well make it worth-while, yes? Custom cam to be ordered tomorrow, along with better valve springs. Other than that, it'll be stock until I can switch to roller rockers. I'm hoping that'll be enough power (any of you know what HP these things make?) to satisfy me until I finish the build (air ride suspension, PI swaybars, selectable locker, etc). At that point, I'll decide whether I want more, which would be supplied by a turbo- but I'm not really even thinking much about that at this point in time.
BTT2011 Mustang GT Premium, MT82, Kona/Saddle, HIDs, 3.73s, 19s, hood/side stripes, UPR 1.5" springs with adjustable panhard bar, and UMI solid LCAs and relocation brackets.
Originally posted by FreshmeatWhy do the valve covers not fit if the valve covers are from the same motor?
CV and Explorer valve covers are the same height. The vacuum tree under the intake is a little different on the Explorer upper. Not a big deal.
Originally posted by Freshmeat? Custom cam to be ordered tomorrow, along with better valve springs. Other than that, it'll be stock until I can switch to roller rockers. I'm hoping that'll be enough power (any of you know what HP these things make?) to satisfy me
Originally posted by MercracerWhat are the specs on your cam?FOR SALE: 89 Grand Marquis GS HO. Quarter mile = 15.8 @ 87mph -- pics http://public.fotki.com/vfr700f2/car...rcycl/mercury/
Junkyard HO, MSD wires, stock Mustang headers, off-road H, Hemi Super Turbos. 3.55 trac loc, HO governor and servo in stock rebuilt AOD. 3-row rad, air pump delete, cop rear bar, wagon rear springs, 93 CV rear discs, 98-02 Grand Marquis wheels, Class 3 hitch, aluminum space-saver spare.
Coming soon: 98-02 front brakes, cop springs, Monroe cop shocks, 96 Cobra wheels w/255/50/17. Better yet, need a nice wagon to put all that stuff in.
