Hey!
I meant to do this 3 weeks ago but I've been gone! So now I'm back home and can get 'er done I'm just nervous about the order of operations here, and not hurting myself when that axle comes free. Never done this job before.
I got bushing kits from es suspension for the rear lower and upper control arms, which means cutting or burning out the old rubber.
At present, and it'll make it easier, the fuel tank and the brake lines are already out.
a) should I leave the wheels on, loosen the driveshaft, let the whole assembly drop to the ground and roll the axle out from there? The plus side is that it'll make the bushings on the axle itself easier to get to, should I need to burn them out or anything.
b) should I put jackstands under the axle and let it drop 1/2" onto them? Should I make an effort to get the springs out of there before I remove the control arms?
thanks!
thanks!
