Originally posted by miamibob
View Post
Why the hell is this fuel pump so loud!?
second option is for a wagon. Third option is for a sedan. Since you don't have that in your signature (rather you don't have a signature), and I'm too lazy/tired to go look that info up at the moment... get the one that applies to you.
Originally posted by sly View Postsecond option is for a wagon. Third option is for a sedan. Since you don't have that in your signature (rather you don't have a signature), and I'm too lazy/tired to go look that info up at the moment... get the one that applies to you.89 Grand Marquis GS.
Putting it here because I keep forgetting to mention it. It's not very exciting at the moment.
the wagon tank is way different... so the pump may be a little different too, but it may also work. No use taking said risk.
Originally posted by sly View Postthe wagon tank is way different... so the pump may be a little different too, but it may also work. No use taking said risk.89 Grand Marquis GS.
if you get the wagon one, you would have to disassemble it and re-mount everything on the hanger from your tank. The fuel pump itself is the same, the hanger assemblies are not. One of them is longer than the other.
Originally posted by sly View Postif you get the wagon one, you would have to disassemble it and re-mount everything on the hanger from your tank. The fuel pump itself is the same, the hanger assemblies are not. One of them is longer than the other.
Apparently there's also a 20 gallon tank for the sedan I didn't know existed. $409. Hm.
Oh, apparently that was for the 5.8L. I wonder if it would fit.Last edited by ootdega; 07-29-2014, 05:32 PM.89 Grand Marquis GS.
yeah, buying from Ford you get assemblies. Most folks here just get the walbro? pump and make it fit in the assembly.
Originally posted by sly View Postyeah, buying from Ford you get assemblies. Most folks here just get the walbro? pump and make it fit in the assembly.
Right then, I'll see where this fits into the priority list and take it from there.89 Grand Marquis GS.
