On my '86 Grand Marquis with apparently 40k original miles, it will start right up immediately when cold and then within a short time the idle is low / running rough and then the engine shuts right off. I just replaced the IAC today and it made no difference at all.
When this happens, you can start it right back up again immediately with no problem and then the cycle begins all over until the engine shuts off again.
Ideas? Thanks.
Ideas? Thanks.
