Roller cam blocks
    Originally posted by Freshmeat
    Handle? What are ya'll talking about? Can't you reach up through the bottom to support a cam if the crank is out?
    Yeah, if I ever did it that way...all of my installs were with assembled motors. Just did cam swaps. I use a really long bolt in the end of the cam as an extension.
      I think I'm going with a roller now. Seems the benefits are worth the price.
      It will also take soe guess work out too. Thanks
        I found out the side handle from the Milwaukee drill I had at work threaded perfectly into the end of my HO cam, so I used that to install it. Made it somewhat easier.
