So, my 87 GM failed Smog. (California) At first, it passed on emissions, but failed on visual due to a broken vacuum line, and one disconnected. (Just replaced the smog pump, must have forgot to reconnect that line.) Then after getting the vacuum lines in order, it passed on visual but failed on emissions. That's annoying. High NO, so EGR seems the most likely culprit...
Pulled the EGR valve, and it really looks fine. Moves with vacuum applied, very little buildup. The plate it attaches to, however, was mostly clogged. No good way to clear that without pulling it off, so a couple new gaskets and a couple hours later, its so much cleaner. (I didn't expect to find a water passage right there, but no biggie.)
Start it up and it seems to be running great, but the idle is high. Not undriveable high, but high. Which leads to my question...
I thought the computer controlled the idle on these things... No?
