Hi all,
Derek and I finally had a chance last night to play with our SnapOn MT2500 Scanner that we scored. We tested it out on both of our Town Cars and code 34 (EGR Closed Valve Signal Too High) popped up for each of us. As you can see, it indicated to check the EGR Valve Vacuum Regulator. We did and it was in the recommended 30-70 OHMS. Any ideas as to where we go from here?
![Click image for larger version
As always, thanks for all the help.
Ashley
Ashley
