1990 Town Car w/5.0L
ON A COLD ENGINE.
Ran the codes for the car - received codes 31, 41 and 91.
31-EGR position sensor below minimum voltage
41-Lean Bank 1 per O2 sensor
91-Lean Bank 2 per O2 sensor
So I cleaned the EGR valve of carbon. no change :-/
Then I noted that I heard a HISSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSSS under the hood for 15 second near the brake booster. And I remembered that its grunts when apply the brake pedal. Typically 1990 model w/factory booster = it's bad.
So...due to the large vacuum leak from the bad booster, I received these three codes because the EGR valve is not opening properly, causing the car to run lean!.
How about that for diagnosis!
ON A COLD ENGINE.
