I was wondering if anyone else on here has ever ran into this problem and knows what it is. Just yesterday my 84 marqee started surging bad at idle. Know when I let idle I'll give gas and it will sputter then rev up an then when it comes back down from revving it slowly chokes and then dies... I have recently replace the fuel pump and the tps thinking it was the tps however the problem continues. I have also tried one of my spare tfi modules and same problem. Any one know what it is? Also it's a cfi 5.0
I'm lost!
It just started all of a sudden too. I hope no one poured something in the gas tank...
Passages being? The two bored where the injectors are? Also I got rid of the egr so all I have where it is suppose to go is a solid plate with a gasket sealing it.sigpic
OH, well then.. I suggested the EGR because typically those passages get all gunky and the pintle on the EGR valve can stick open and cause what you've described. But, since you've eliminated all of that my best guess is perhaps you've got a vacuum leak somewhere.. When did you last change the fuel filter? What's your fuel pressure? No idea what CFI cars run at but someone on here probably does and that is pretty easy to check.1985 LTD Crown Victoria - SOLD
I'm voting for vacuum leak if the EGR isn't stuck open. The line to the MAP is very important.86 Lincoln Town Car (Galactica).
Doesn't it have a type of choke like a carb? Might check to make sure that's not closing too much or staying way open.
Originally posted by sly View PostDoesn't it have a type of choke like a carb? Might check to make sure that's not closing too much or staying way open.1985 LTD Crown Victoria - SOLD
It completely shuts off when cold. When warmed up it chokes about to die comes back up chokes and sometimes dies. I changed the fuel filter when I changed the pump about a week ago. Rented out a pressure test and just my luck it was missing the adapter for the ford Schader valve.sigpic
Also when I drive it I could give it 3/4 gas and it'll will not accelerate at first I thought it was the transmission that's how bad it was.. In neutral I'll rev up to 1000 rpms and try to hold it there but it will not stay steady and fluctuates like crazy. Go up to about 2500 rpms and it'll hold steady.sigpic
Certainly seems like a fuel delivery issue or spark issue. You can check the pressure with any ole tire pressure gauge. If you use one of the stick type ones it will be garbage after but at least you'll have your answer.. A lil fuel will spray up of course so have rags ready. While you're there, check the vacuum line to the MAP sensor like gadget mentioned and maybe even try swapping that out if the line is fine.1985 LTD Crown Victoria - SOLD
The CFI system is way too dependant on proper vacuum signals, and there are entirely too many vacuum lines on these engines, and 90% of them are routed in a most stupid way. Hate to say this, but pop your air cleaner assembly off, and start tracing EVERYTHING back there. If anything looks questionable just run a complete new line. While you're at it, elliminate all the T-ees that have capped-off ports and 2" long connecting hoses - you'll see what I'm talking about when you start digging into it, it's a clusterfawk to say the least, and from a functionality standpoint it makes exactly zero sense to have all that junk the way the factory set it up.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Update.. Day two.
So I changed the fuel pressure regulator last night and same symptoms. So I traces the hose to the map like many suggested. And I replaced it with the old map sensor I had... And the symptoms got worse! So decided to order a new one. I hook it up this morning and the car doesn't even crank over. I put the old one in and it starts. But I think it's the connector not making a connection to the new one. It's all corroded and doenst even clip cuz the plastic broke. So I ordered a new one that imma solder in. Unfortunatly it does not come in till tomorrow....sigpic
That would do it. with no MAP signal it goes into a uber stupid mode and generally doesn't work.
