Hey yall,
When I'm cruising anywhere from 50mph and up I can feel a slight miss every 3-4 seconds. You can barely feel it, but it feels like something is holding the car back for a brief moment. It's like a slight pause. It's not that bad, but the wife and I can feel it. I was hoping as I replaced and cleaned things here and there it would fix itself, but so far no luck. Here's a lists of things I've done so far.
Motorcraft copper plugs/wires
Air filter
Fuel Filter
Fuel pump relay
Motorcraft cap/rotor
2 Vacuum lines from under the intake
1 Vacuum line from the vac tree to brake booster
Motorcraft TPS
Thoroughly cleaned the IAC
Thoroughly cleaned the Throttlebody
Fuzzy Dice
Any thoughts on what I should look at next? I thought maybe I should get a new IAC, but I don't feel the miss on idle. Just when cruising at 50 and above.
Air filter
Fuel Filter
Fuel pump relay
Motorcraft TPS
Fuzzy Dice
