I noticed when I had my front accessories apart that the freeze plug on the front of the passenger side cylinder head has a small leak; very slow, but noticeable residual fluid after a day or two. Rock Auto shows two plugs available, a standard and .060" oversize. Would the standard be the one to get? Any tips on installation? It's really a slow enough leak to just ignore, but it's behind a stamped steel accessory bracket; I don't want it to start rusting the bracket (there was already a little bit of surface bubbling of the paint on it when everything was removed for cleaning.
Replacing freeze plugs
Use the standard size ones in brass. Not really much magic to it if you have access. Drain the coolant, knock the plug out, clean the hole thoroughly, put some sealer shmoo on the plug, drive it in with a suitable sized socket until its flush. I've used Permatex #2 or aviation sealer but any semi-thin non hardening sealer will get the job done. RTV probably will also work fine, just don't put gross amounts of anything on there or the excess will end up as little bits of trash floating around in the cooling system to clog up the radiator.
Something to warn you about, if one is bad, the rest are probably fairly shitty too. You can get to two of them, there are a total of I think 10 on the engine. 4 on the heads, 6 on the block. None of the others can be gotten to without removing the engine. You can see all but the ones on the backs of the head without too much bother.Last edited by gadget73; 12-29-2016, 06:46 PM.86 Lincoln Town Car (Galactica).
FYI, NAPA can get you stainless freeze plugs, cheap too! Gotta go by size tho, and they'll have to look in their books to find them. Good chance they're actually in stock too. Also no need for overize that I can think of, standard is just fine.The ones who accomplish true greatness, are the foolish who keep pressing onward.
Not sure why you'd even need oversize. The hole would have to be bored out to take it. I guess maybe thats for if the original hole is so dicked it won't seal anymore.86 Lincoln Town Car (Galactica).
Thanks. I wonder what's going to go first with this motor.—John
1985 Ford F-150 XLT Lariat
Originally posted by gadget73 View PostNot sure why you'd even need oversize. The hole would have to be bored out to take it. I guess maybe thats for if the original hole is so dicked it won't seal anymore.The ones who accomplish true greatness, are the foolish who keep pressing onward.
possibly excessive corrosion?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
I replaced them on a set of heads I was rebuilding.
Might be something you see on marine engines. They rot from the inside horribly, unfortunately by the time they show signs on the outside, the inside is far enough gone to warrant replacing it. Nothing quite like finding the engine filling itself with water because there is nothing between tthe water jacket and the exhaust ports anymore.86 Lincoln Town Car (Galactica).
Yes I lost two engines over the years with that.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
I had to replace that head freeze plug on my 88. So far it's the only leaker and that was five years ago. In other news, I say pull that sucker out and replace all the freeze plugs, reseal the thing, and investigate those mysterious noises it makes. Or leave it all alone and save up for a Explorer swap in due time.1990 Country Squire - weekend cruiser, next project
