If that replaces the bracket entirely it may not work. If its an adapter that uses the original, it will probably fit. Honestly at the moment its working so I'm not likely to screw with it.
power steering pump specs?
It's a horseshoe-shaped adapter - Sagi pump uses four bolts in a trapezoid pattern, the horseshoe adapts it to the triangle the C2 pump bracket has. But yes, if it works right don't mess with it.The ones who accomplish true greatness, are the foolish who keep pressing onward.
