Idle Air Control Valve Questions
    Was reading that some cars have a diode in the wiring leading to the IAC and that replacement IAC's may come with the diode already installed internal to the unit and that removing the factory diode from the harness is suggested.
    hey whats up people? i bought a code reader for my car and its giving me the codes 31 and 85. Has anybody dealt with these codes before and if so could you point me in the right direction. i have taken off all smog and ac equipment, i used a EGR delete plate as well but i haven't put in a dummy plug yet, that was about 2years ago so im thinking that is what Code 31 is. The car also just start having the idle bounce around between 750 and 1200, im hoping by fixing these codes that it will fix
    Anyone hear something like this?
    First I've heard of it. Don't know why you would remove the diode as it would essentially work as a backup in case the other failed.
      never heard of it but I just had a look in my 86 and 91 EVTM. The 86 book shows a diode in parallel with the IAC. The 91 book shows an IAC with an internal diode.
      Its a flyback diode. The only thing it does is conduct when the power is removed from the coil in order to keep it from back-feeding a spike of voltage. No reason you can't have two in parallel. Its not dropping any voltage or anything of that nature. Only real argument I can make for removing it is that if the one in the harness goes bad it will act like a bad IAC and replacing the IAC won't fix the problem. Never honestly heard of anyone having that problem and diodes are like 10 cents so NBD.
        Cool. Just wanted to bring this question to this forum and see what feedback comes of it.
