Is a cast iron water pump preferable over an aluminum one? I know that the tow package cars came with the cast iron one but what was the reason for this?
My water pump needs to come off due to a leak around one of the ports. I read that the cast iron pump uses an extra bolt around each port. I知 considering switching to a cast pump because of this. Is that the only functional difference between the pumps?
