Honestly anyplace with half a brain that can work on older stuff is capable of doing brake lines. its not rocket surgery by any stretch, its just a pain in the ass. You can even do this yourself, just need the flare tool and some patience.
Break Line rusted out, leak, no power breaks
Originally posted by gadget73 View PostHonestly anyplace with half a brain that can work on older stuff is capable of doing brake lines. its not rocket surgery by any stretch, its just a pain in the ass. You can even do this yourself, just need the flare tool and some patience.
Yes brake lines should be bread and butter for any competent shop or patient DIY. I was thinking that SBF stuff and older ford in general and mustang "specialists" might be a good thing. Though any shop with some decent older mechanics would probably be AOK.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
You need a shop that still values "old time mechanics" who can diagnose an issue by "sight, smell or sound". Most younger ones can only function if they can attach a computer to the car. Without that, they're screwed! Of course, there are exceptions but they tend to be the exception rather than the rule.What I Own: 1993 Mercury Grand Marquis GS
I hate to be the negative one here, but did you look under the car to inspect the job they did? Too often I see where "mechanics" tie wrap new lines to the old ones, loop new lines around rear axles because they were too lazy to cut/flare the lines to length. I also have seen compression fittings used joining old lines to new ones. WagonMan89 Colony Park
90 Colony Park
70 HEMI Daytona Convertible
Once you make a few proper flares, it should be fairly easy. Use a tubing cutter, make sure the tubing is cut flush, remove any burrs with a file. Don't over or under flare the tubing, most important make sure you install fittings before flaring lmao. Also be mindful of they type of flare: single flare, double flair, metric bubble flair, etc...
Originally posted by WagonMan View PostI hate to be the negative one here, but did you look under the car to inspect the job they did? Too often I see where "mechanics" tie wrap new lines to the old ones, loop new lines around rear axles because they were too lazy to cut/flare the lines to length. I also have seen compression fittings used joining old lines to new ones. WagonMan..
I dunno what kinda professional bullshitters call themselves mechanics over on your side of the pond, but even the cheap shops can do brake lines in Finland. I'm pretty sure leaving the old (unused) lines in place is a fail in an inspection, so even the cheapest shops remove the old lines, like you should.1985 Mercury Grand Marquis LS, "Maisa"
Not everywhere does inspections, and not everyplace does quality work. There really isn't any sort of requirement to open a shop. No formal training, no proof of ability, just need a business license and all that if you want to go legit. So long as you can pay your taxes nobody really cares about the rest of it.86 Lincoln Town Car (Galactica).
