Originally posted by Toploader
View Post
87 Grand marquis 5.0 Sefi
Look up Ford TFI tool. Several companies make them and they are not expensive. Amazon, Ebay and many local stores should carry them. Here is one example:
https://www.walmart.com/ip/Lisle-646...SABEgJ2T_D_BwEWhat I Own: 1993 Mercury Grand Marquis GS
Or swap out the 7/32" hex bullshit and put in some allen cap screws or philips heads and get an offset screwdriver / allen L-key.
- Likes 1
Originally posted by Arquemann View PostOr swap out the 7/32" hex bullshit and put in some allen cap screws or philips heads and get an offset screwdriver / allen L-key.What I Own: 1993 Mercury Grand Marquis GS
If the hardware is lost maybe? Easier to replace. Also in my case the nearest walmart is quite far away.
I'm not a fan of unneccessarily specific tools, especially in a critical use case. But I guess one of those won't hurt too much to carry in a car.
- Likes 1
Originally posted by Arquemann View PostIf the hardware is lost maybe? Easier to replace. Also in my case the nearest walmart is quite far away.
I'm not a fan of unneccessarily specific tools, especially in a critical use case. But I guess one of those won't hurt too much to carry in a car.What I Own: 1993 Mercury Grand Marquis GS
When I was running 2+ hour interstate commutes before I had a cell phone, I just carried an extra distributor since it was just one 1/2" bolt. Never needed it.1990 Country Squire - under restoration
A regular socket which has been ground a bit thin works just fine.
even one of those ultra cheap china made ones are ok for this.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
Originally posted by jaywish View PostA regular socket which has been ground a bit thin works just fine.
even one of those ultra cheap china made ones are ok for this.What I Own: 1993 Mercury Grand Marquis GS
the problem with the tool is getting it in there. Half the time the distributor is at a spot where it won't fit unless you un-clamp it and rotate. The hex key gets you around that.
or just carry a distributor, honestly its about as easy to swap the whole thing out, and it also gets around the possibility of a dead pickup. I have had two ignition failures in my nearly 20 years of driving these cars. One was an honest to goodness TFI failure, the day after a water pump failure caused a serious engine overheat. The other time the magnet fell out of the distributor. The 240k mile TFI module was absolutely fine and I still have it around as a spare, but the pickup was junk. Called 86VickyLX for a rescue and he brought me a spare distributor to chuck in on the side of the road. When the TFI went TU in the Towncar, I got my stepdad to bring me the spare distributor and I did the same thing. If your ears are good you can get it damn close without a timing light. Both times I stabbed it and went I was within 2 degrees when I got home to check it.
The other time I thought it was an ignition problem was actually the timing gear fell off, but thats a different matter entirely.86 Lincoln Town Car (Galactica).
- Likes 1
