What kind of luck have we had with box coyote swaps? Bout to get a second 88 town car. Want to start reading about the swap. It looks like there's a motor mounts kit for the foxbody....any reading material or links would help.
Box coyote swap
Logan...user name bobcat put one in his car: http://www.grandmarq.net/vb/forum/te...vic-coupe-cvgt
Dont know if it is documented all that much but he definitely has installed a couple of coyotes into that car.~David~
His car is a frame swap car ('03+) as well. Coyote mounts are actually available from a few places for the later chassis, primarily because folks will swap the front cross member and sometimes frame stubs from the later cars into older F series trucks, with a yote swap.
https://www.outcastautoworks.com/pro...-package-price
^This guy makes nice stuff.
The frame swap is a really nice update to the chassis and would facilitate your swap. You might need to modify a CV/GM chassis, or specifically use a TC chassis as I believe the wheelbase is slightly longer on a TC.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
