Brand new 306 build. Cracked upper intake. Will require new. They gave me the car with no coolant in it. Will a trick flow street burner upper and lower fit on the gt40 p heads?. The cracked upper and lower are lightly ported explorer intakes. The cam is basically like a comp xe 258. Thanks guys.
The heads don't care what intake you bolt to them. Only trick is going to be hood clearance and whether or not you can flip the intake so the cables and such don't route in a dumb way. I think the TFS will but not sure.
If the intake isn't totally trashed, it can be welded back together. I had an Explorer intake off a truck that had rolled. There was a spiderweb of welding around the back two bolts on the upper to fix the cracks on it. Wasn't real pretty but it worked absolutely fine and the ugly part faced the firewall. I think John actually ended up with that intake, no idea what it went on.86 Lincoln Town Car (Galactica).
- Likes 1
I asked several people. The idea of welding aluminum seems to really turn people off. They were telling me it's not repairable. I didn't think about the trick flow stuff facing the other direction. Does that leave me with explorer options? I spose the lower is still good. Will it matter too much if it not port matched with the new one? I may be able to find a ported one.
Cast aluminum takes some experience to weld properly from what I've heard. JB Weld is always an option as well, but you will have to work it into the crack and then sand things smooth for mating surfaces once it's cured.
The TrickFlow looks to be reversable with no issues just like the stock intakes. Just make sure that the throttle body size is the same for the TrickFlow.
Some castings are better than others. I don't know enough about welding anything to offer any really solid advice, other than I had one that was welded and it worked out OK. No idea how it was done either. Friend of a friend thing, he took it to work and it came back in one piece.86 Lincoln Town Car (Galactica).
Tig?03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
what are you using to get 48mm from throttle body to spacer? That should be the same size all the way through, or at least not smaller than the throttle body. If thats a stock lopo part, thats not doing you any favors. they won't reliably bore out past matching the ID of a stock HO throttle body, but thats still noticeably bigger than 48mm. The one I bored out a month or so ago is 2.355" or 59.8 mm. I matched it to the HO throttle body I had sitting around. This particular one might do 65 but I don't know about trying for more. I've done some that 60 was all I felt comfortable removing and still having a good chance at a proper gasket seal.86 Lincoln Town Car (Galactica).
- Likes 1
sounds like its time to pull some things off and measure for yourself to confirm whats actually going on. Its not such a big deal to go up in size but you don't want a smaller part in the middle. It causes lots of turbulence and airflow disruption. More ideal to have a smooth transition from one size to another if posssible.
also just curious what specific mix of parts you are currently using.86 Lincoln Town Car (Galactica).
- Likes 1
Me two man. I get lied to a lot. They probably have a different person work on it every time. I had to tell them to switch the firing order. It took them months to put in the motor I had built. Il grab their micrometer and measure all of it if they let me. I think people rush through things and put zero due diligence to anything. You can't really pay to have anything done where I am. I had to print them out the 3g conversion twice. They tried to give me the car several times not finished. Nobody holds their word. It's actually pretty insane. Waiting on that speed shop. Hopefully they will properly check it for vacume leaks. Make sure it's actually done. I'm not mechanically inclined or I would.
- Likes 1
