look like hybrids, definately a t3 center and hot side, and kinda looks like a 50 trim front... Ford wastegate setup...
Twin turbo 351W box...
Originally posted by Pirate View PostIs it just me, or does it look incredibly cobbled together in some spots?
Also, aren't those turbos kind of small? I'm not really up on turbos, but they look tiny to me. Obviously they aren't like some of the huge ones I see on cars in MM&FF, and understandably so.
definitely lots of work though, and that I can appreciate. I don't want to bust this guy because he has something truly unique.**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
Originally posted by P72Ford View PostI'd definitely agree, not that I want to discredit someones hard work. I have seen much worse fab work, but it does look a little goofy. The carb set up is lame IMO. He should have gone with EFI; the idea of turbos blowing through a carb isn't appealing to me.
and when you use twins you can use small turbos. two turbos off of MT turbo coupes are big enough for a mild 351http://secondhandracing.com/Home.aspx
Originally posted by DuceAnAHalf View Postnothing wrong with blowthrough carbs. a guy i know has a 306 with ported edelbrock performer heads, blow through c&s carb, 80mm turbo. runs 9.60s @145 on 17psi, thats on a 8" tire and stock suspension
and when you use twins you can use small turbos. two turbos off of MT turbo coupes are big enough for a mild 351**2012 Ford Mustang Boss 302: 5.0/ 6 spd/ 3.73s, 20K Cruiser
maybe I'm dumb, but why is there a spark plug in the plumbing on the passenger side? Does that serve some actual function, or is it probably just there plugging a bung ?
and good lord, the smog pump is still there lol
Still, pretty badassLast edited by gadget73; 10-02-2007, 10:56 PM.86 Lincoln Town Car (Galactica).
Originally posted by gadget73 View Postmaybe I'm dumb, but why is there a spark plug in the plumbing on the passenger side? Does that serve some actual function, or is it probably just there plugging a bung ?
You know, I noticed that too and then promptly forgot. I'm pretty sure I've heard something about running a turbo motor a little rich at low RPM and then lighting off the raw fuel in the exhaust to spool up the turbos in a hurry - but never having built a turbo car, I may have it completely sideways and upside down. :p2012 Mazda5 Touring | Finally working on the LTD again!
the picture caption says that its there filling in the O2 sensor bung.http://secondhandracing.com/Home.aspx
Originally posted by P72Ford View PostThanks for clearing up the turbo issue. I'm sure theres no problems with running a blow through carb (I've seen it more than a few times). However, it just doesn't sit right with me. It wouldn't be something I'd do personally.
It is silly to try and tune a blow through carb in your backyard. There are professionals who can tune a blow through setup making 1000HP or more.
Even if you cobble together a home built turbo system to save money, you should be spending the money on a professional dyno tune or you have more than likely built more of a bargain engine killer than a bargain performance engine combination.
