also, do i need the intake, or can i just keep my stock intake and use everything else from an HO?
HO Conversion - Mike's Tips and FAQ
This is a sticky topic.
Huh? There are 2 options for EGR. 65MM Lightning or a stock egr bored over to match the 60mm(stock HO) throttle body.
Everything that needs to be done is in the first post of this thread.Builder/Owner of Badass Panther Wagons
No problem. The HO upgrade is great, because it utilizes all the part the mustang guys don't want. So, it's generally a very inexpensive upgrade. The stock HO parts can be had for free if you know any mustang guys.Builder/Owner of Badass Panther Wagons
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
The upper intake needs to face the other way. It can be put on so that the throttle body faces either the passenger side or the driver's side, and it needs to be put on facing the driver's side.
you do not need a higher stall converter if you use 1.7's... As for spinning the intake- the mustang upper is installed in the opposite direction as the vics/grand marq's.Builder/Owner of Badass Panther Wagons
- Sep 2011
- 7373
- Big Rapids, MI
- Send PM
The only reason to change to a higher stall is if you're making changes that would move the powerband up in the RPM range.
