like the smog pump does anything lol, my old mand wagon passed with the smog pump unhooked and read 0 hydrocarbons lol
HO Conversion - Mike's Tips and FAQ
This is a sticky topic.
Originally posted by pollock View PostCan you still pass an emissions test after converting to HO?
Assume smog pump and cat(s) are intact.
Shouldn't be any reason it wouldn't Remember, an HO motor is a stock ford motor that has to meet emission requirements also. My car fast passed MD emissions every time.Builder/Owner of Badass Panther Wagons
Originally posted by mrltd View PostShouldn't be any reason it wouldn't Remember, an HO motor is a stock ford motor that has to meet emission requirements also. My car fast passed MD emissions every time.
quick question, will an HO cam work in an 84 block? from what i hear the rollar lifters wont work in the 85 and down blocks,just want to clearify that. and im not sure if i can use regular lifters on an HO cam, there is a 91 T-bird at the wreckers i work at with an HO in it so im planning on getting the heads and cam out of it, and swapping to a 4 bbl on my merc
Can't use a roller camshaft in an 84 block unless you buy those expensive link bar retrofit lifters. Can't use flat lifters on a roller camshaft either.86 Lincoln Town Car (Galactica).
Save The Trouble Bore The EGR Plate To 63mm,Put A Slight Round On The Face Get Explorer TB Gasket,RTV And Put The 65 On...No BSsigpic351w .030, B303, 1.6 Roller Rockers, GT40P Heads Mild Port Job,351w Lightning Lower & Explorer Upper,65mm TB, Custom CAI, 24# Injectors, Adj FPR, 1/2 Phenolic Spacer, TPS Enhancer, Shift Kit, 2400 Stall, Hi-Rev Govenor, MMC Alcoa Driveshaft, 3.73 Trac Lok, Underdrive Pulleys, Electric Fan, MSD Street Fire Coil, MSD 6AL Ignition 12.35 @114 mph spinning through 1st gear
Could I just drop the 94 HO engine out of my Bronco in my Marq? (with the exception of swapping to the stang intake and swapping the oil pan and whatnot.
I've been told by some not so well informed mustang guys that the truck engine won't accept the Mustang intake. I don't see why they would be different.
I've been trying to part out my Bronco for like a month and it's just not happening so I might just use the motor.
Was also thinking of putting the marq on the Bronco frame, lol.'92 F-350 4x4: 7.3 idi, E4OD, 6" all spring Skyjacker lift, 16.5" Mickey Classic II's, 35" BFG's, Loc-Rite Up front, Trac Lock in rear.
'91 Lincoln Mark VII Bill Blass: don't know yet
Bronco frame is too short. But I'm almost positive I've figured out how to put the ttb front end under the car.1989 Grand Marquis LS
if you have a CFI car, you will have to convert to SEFI to use HO parts but, the best would be to put a HO engine+wire harness in the car.
the CFI system looks like a carb but, with 2 fuel injectors feeding all cylenders, the SEFI system consists of a upper intake plenum and an injector for each cylender.
