I have an annoying oil drip coming from the drain plugs on the oil pan. The front is worse than the rear. The drain plugs are not stripped and the oil pan is in new condition. The drain plugs do have steel washers on them. The plugs from my old engine have a nylon washer on them but are a different size than the ones on the HO. Have been told copper washers would fix this. Telfon tape on the drain plugs did not work. Anyone have similar experience or ideas?
annoying oil drip
annoying oil drip
NA-15.78@91.21, 80hp shot-14.48@96.21Tags: None
there's no washers at all on mine and the plugs don't leak. try just taking the washers off.
no washers on mine = no problemsigpic
replace the drain plugs.....if thats a later 302 they are metric
13mmsigpic
Thanks, I'll remove the washers and see if that does the trick. The plugs are metric.
Since my last post on this thread, i finally fixed the oil leak today. After following your suggestion to leave the washer off to no avail, and was only able to slow it down with a copper washer and teflon tape, finally just put telfon thread dope and kept the copper washer on it. Problem solved. Will probably just start changing oil through the rear plug. With the car on ramps i noticed less than 1/2 qt. oil comes out the front plug.
are these new plugs? Mine don't leak since I replaced the drain plugs entirely. I think mine have the rubber gaskets. The Mark VII had one original plug and one replacement when I got it. They weren't quite stripped per se, but the threads were extremely sharp on the original plug so the oil just wicked around the plug and dripped. New plugs fixed it right up.86 Lincoln Town Car (Galactica).
