Originally posted by 86VickyLX
View Post
Explorer swap with codes
Originally posted by pantera77 View PostIt's a Powermax 2020 (Formerly Compucam 2020) According to the spec sheet.
Originally posted by 86VickyLX View PostAh. Now, if you let it idle, will the backfiring go away? Like you start it up, it's idling, then as it warms up, it idles really funky, then out of nowhere the idle goes back up steady? If it does that, it's the same problem experienced with my engine, and P79's engine, when it was fuel injected...2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Originally posted by pantera77 View PostI honestly don't know, but that may explain why some times it would drive fine, and then other times every time I had to accelerate from a stop it would get so bad it would nearly stall.
When it starts to warm up it'll get all weird with the idle, then it would come back up. Then it should drive better...
Originally posted by pantera77 View PostThis is what I don't understand. The 89 has a full explorer swap, is still MAP, and runs like an absolute champ. No problems at all.
The wagon on the other hand, has e7's, an aftermarket cam (supposedly SD friendly), explorer intakes, and does the BS hesitating, popping through the intake, ect.... It's going mass air come spring.Give a man a fish and he will be fed for a day. Teach a man to fish and he will promptly forget that he once did not know, and proceed to call anyone who asks, a n00b and flame them on the boards for being stupid.
Originally posted by cld783 View Postis the 89's cam straight up and the wagons advanced 4 degrees?2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
Originally posted by 86VickyLX View PostDo me a favor. I know it's cold out so it will take longer, but go out and start it. You have a temp gauge in it?
When it starts to warm up it'll get all weird with the idle, then it would come back up. Then it should drive better...2020 F250 - 7.3 4x4 CCSB STX 3.55's - BAKFlip MX4
