Put a b cam in my motor, got the timing all lined up, 351 firing order, i am NOT 180 out. wants to start but will die when i lay off the starter. Any ideas?
B cam no worky
Yeah gotta know what induction system.
If It's any consolation the B cam isn't that good anyway
maybe it's the duel exhaust. Fighting is never good.
Yeah, need a little more info. You cant just slam an aftermarket cam in and expect it to work. Carb or not there is a lot of other stuff needed. With EFI, you need different ecu, injectors, and should have bigger TB and upper intake at a minimum.
And it really won't work well with a speed density efi setup.
Well, a few seconds of serching I found that you have an 89 with a GT40 or explorer intake. You need a mustang ECM, injectors, and with that cam, a mass air conversion. And if all of this is on stock heads...LMAO.....Builder/Owner of Badass Panther Wagons
if you got speed density i suggest getting a powerful speed density friendly cam. there are a few i hold one for my upcoming motor build a crower 15510.
if you got anykind of cam, MAF is the way to go. dont bother messing with SD.
IIRC the problems people were having with SD systems and cams/explorer top ends were running lean and backfiring, but they were at least running. It's definitely not helping the situation if you're still running speed density but I don't think it would keep it from running at all. Could be wrong though, none of those guys used a B cam...not sure what the specs are on them
Sounds like what my car was doing when I fucked up the firing order and ran it clockwise instead of counterclockwise, though. Just a thought. Occam's Razor and shit.Last edited by 1990LTD; 01-14-2012, 07:37 PM.sigpic
^good point. these engines will run somewhat. tripple check your timing for a start. then go over spark and fuel. but like said before, is it EFI or carb?
If you pump the crap out of the gas will it run?
I'd also double and triple check the vacuum lines and stuff. if the map sensor isn't connected it'll act stupid. So many things could be wrong after pulling the top end apart.Builder/Owner of Badass Panther Wagons
Originally posted by 86VickyLX View PostHe could, however, it would confuse the fuck out of the ECM when it needs to adjust the fuel trim... I don't advise it...
I have repined the ECM on several of my cars and some others and have seen no side affects. Driven mine for over 100K. Talked with several Ford calibrators that stated the programig in the older ECMs wouldnt know the differance. Got excelent economy. Might do it again on Casper if the opertunity presents itself.Scars are tatoos of the fearless
The stock ECM is also designed to fire a 14# injector, which isn't nearly enough.
And yes, the programming will know the difference in a sequential system. Not in batch fire, but on batch fire you'd never need to rewire it. On the other hand, honestly the injector firing isn't super critical. If it fires when the valve isn't open, the fuel simply puddles on the back of the intake valve until it opens. Its not optimal since you have no atomization to speak of, but it won't make an engine not run because of it. You may get a slightly rough idle, but thats about the worst of it. The fact that it won't idle at all is not likely because the injector order is different than the ignition order.86 Lincoln Town Car (Galactica).
