i removed my smog pump at the beging of winter because the bearings where shot i still have my ac pump on and wanted to know if there is a belt i can buy for just the ac and if you all new of any part #s. thanks
is there a smog pump delete belt
1984 mercury grand marquis ls rebuilt 306 flat top pistons with factory cfi and lincoln headers with single glasspack dual snorkle air cleaner. Gloss black paint with slick top coversion.
1986 mercury grand marquis colony park 5.0 sefi dual exhuast thrush turbos with h pipe and turbinesTags: None
Should be a 560K6 if I remember right. If its not that, its a 500K6. One of those is the stock alternator belt, the other is the smog pump delete. Pretty sure its the 56" for the smog pump delete.86 Lincoln Town Car (Galactica).
okay thanks gadget. i want to get the ac working again as im not going to do another summer with out it. last year i noticed that my ac didnt work as there was no freon in the system. are there any specific spots on panthers where they leak. and i just got the belt and it fits. thanks1984 mercury grand marquis ls rebuilt 306 flat top pistons with factory cfi and lincoln headers with single glasspack dual snorkle air cleaner. Gloss black paint with slick top coversion.
it's the 560K6. a 565K6 would work a little better though... but I don't think that's a standard size.
They leak specifically at all the spots with an O ring or a crimp around the rubber hose. Which is every connection. They also sometimes leak from under the low pressure switch. I hope that narrows it down some
Generally though, its the O rings. Replace them all and see what that gets you. A kit of the O rings is pretty cheap. It would also be wise to replace the drier if the system has been empty a while, and I'd give thought to changing the orifice tube as well. If you're charging with R134A, or something else that doesn't use mineral oil like the old R12 did, you may want to flush the system of the old oil and refil with the proper type for your refrigerant.86 Lincoln Town Car (Galactica).
many times I've just needed to snug up the Schroeder valves.
Originally posted by 84merc951 View Posti removed my smog pump at the beging of winter because the bearings where shot i still have my ac pump on and wanted to know if there is a belt i can buy for just the ac and if you all new of any part #s. thanks88 Town Car (wrecked, for sale)
Y/H pipe... fit a large bolt in there or weld shut at the cats (I finally did the latter recently). I removed the smog pump solenoids and all vacuum lines associated. It eventually came down to removing a T that fed them and putting an in-line coupler in it's place. Replacing almost all the hard lines with regular vacuum line to compensate as well.
yes as slymer stated. i use the same set up with an inline coupler1984 mercury grand marquis ls rebuilt 306 flat top pistons with factory cfi and lincoln headers with single glasspack dual snorkle air cleaner. Gloss black paint with slick top coversion.
i got a 565 belts work much better than the 56. 56 inch very tough to get on.
Originally posted by MattsTownCarSS View Posti got a 565 belts work much better than the 56. 56 inch very tough to get on.
if I have to replace the belts on my cars... 565k6 will definitely go in.
89+ compressors are slightly different, needs a slightly longer belt.86 Lincoln Town Car (Galactica).
