Along with panthers, i also dabble in the slightly off-kilter world of the Taurus SHO. I've accumulated parts over the years and among them is a 3.4 liter V8 and associated parts. The stock MAF size for these engines is 80mm. But theyre also OBDII. If i wanted to use this as an alternative to an aftermarket MAF for my up coming improvements on my '91, what would i have to do? Will i need a tune? I plan on using either an A9L or an A9P.
V8 sho maf?
needs a tunesigpic
Probably need more than a tune with a 6-wire MAF sensor. The '92-'94 and maybe a few other years CV's and GM's use the "70mm" maf...cut out the center bar leaving only the sampling tube and MUST use fox MAF electronics....also take out the little bit of casting flash and will actually measure 73mm. If you use the stock electronics in a mod'd housing it won't work worth a crap. I have one from an early 90's t-bird with electronics ready to go...only difference is, it isn't flanged on the air box side. Let me know if you're interested....don't need it with my new FAST EZ-EFI set-up.
Good luck,
Don'85 CV coupe- 351W, T5-Z, FAST Ez-Efi, shorty headers, 2.5" duals with knock off flowmasters, 2.5" Impala tails, seriously worked GT-40 irons, Comp 265DEH cam, 1.7rr's, Mallory HyFire 6A, Taylor ThunderVolt 50 10.4mm wires, 75mm t/b, 3G alt swap, 140mph PI speedo, PI rear sway bar, '00 PI booster/MC, 95-97 front spindles, '99 front hub bearings/brakes, '92-'94 front upper control arms/ball-joints, 3.73's with rebuilt traction-lok, '09 PI rear disc swap, '96 Mustang GT wheels with 235/55R17's.
The 6 wire MAF is a 4 wire MAF with a 2 wire intake air temperature sensor. There is an adapter available from rjm to plug the 6 wire MAF into the 4 wire harness, or you can change the plug. And you need the tune.86 Lincoln Town Car (Galactica).
For the price of a quality tune, you could just get a FAST EZ-EFI set-up and never have to worry about it again! lol
I would say the benefit of an 80mm vs a 70/73mm far from justifies the price of a good tune...then again if you really NEED a maf that big...chances are you're long overdue for a tune anyway. Going that big isn't much of any benefit until you're well over 400rwhp...bigger ISN'T always better.
Good luck,
Originally posted by sick88tbird View PostFor the price of a quality tune, you could just get a FAST EZ-EFI set-up and never have to worry about it again! lol
Good luck,
Don1992 SHO(what's left of it)
1986 F-150(rust and option free)
1950 Studebaker pickup(moves-kinda, stops-no)
1987 T-bird(dead 3.wait, SHO swap in store)
1991 CV $500 cream puffF
It's a tiny window of learning...lol. With that big of a housing you're MAF voltage will be all whacked out somewhere along the line...I was completely amazed when I did the 70mm housing with the center bar removed and fox electronics...voltage was dead on and A/F was right on...car woke up pretty good too.
Good luck,
The adjustable MAF thing is bogus. It just fools the ECM into sort-of working with different injectors. Definitely not the optimal way to do that.86 Lincoln Town Car (Galactica).
