Originally posted by His Royal Ghostliness
View Post
Anyone Build 302's for MPG? And General Wagon Economy
Originally posted by His Royal Ghostliness View PostYou have a good 5-speed already tho... Too bad it's the wrong bolt pattern for a 4.6 engine. Then again I wouldn't go hacking and slashing into a nice whale just for hypermiling purposes - now if the slushbox went poof then all bets are off
Something to consider about wide ratio transmissions is the broadness of the engine's torque band. If its not wide enough to mate up with the RPM change caused by each shift, you're likely worse off.
A properly maintained automatic should be good for at least 150k, and probably upwards of 200k unless its just a shitty transmission. The 4R70/75 should have most of the bugs worked out by now. I wouldn't expect one to die early at this point. They've been working on the design since 1980, its pretty mature at this point. Probably about time to kill it off now that its reliable86 Lincoln Town Car (Galactica).
What Thain said. Before I learned about power bands and the importance of torque down low I'd throw my four banger ranger in fifth any time I was cruising steady. I couldn't figure out why I was getting mileage in the middle teens. So the only change I made was running it in fourth and my mileage went into the low twenties, not to mention the engine sounded much happier. Can't believe I did that...1985 LTD Crown Victoria - SOLD
Originally posted by turbo2256b View PostA stupid high gear would depend on an engine build, a stock engine does well with high gears running around 1800 rpm. A built engine might do better with lower gearing on the highway as the power curve comes in at a higher rpm and possibly do better in economy. I have built quite a few engines based on just improving volumetric efficiency which usually increases power and economy.
Originally posted by gadget73 View PostSomething to consider about wide ratio transmissions is the broadness of the engine's torque band. If its not wide enough to mate up with the RPM change caused by each shift, you're likely worse off.
Originally posted by DerekTheGreat View PostWhat Thain said. Before I learned about power bands and the importance of torque down low I'd throw my four banger ranger in fifth any time I was cruising steady. I couldn't figure out why I was getting mileage in the middle teens. So the only change I made was running it in fourth and my mileage went into the low twenties, not to mention the engine sounded much happier. Can't believe I did that...The ones who accomplish true greatness, are the foolish who keep pressing onward.
ah yes, the old "econ-o-meter". Hell, that became a standard feature in the late 70s in some things. It does work, even with an EFI motor it can tell you stuff.86 Lincoln Town Car (Galactica).
Heck mine was never that fancy, just your standard shop equipment type just left laying on the floor where I can see it. May have had a ziptie to kinda keep it in place, but I doubt it Does work indeed, just gotta know what your engine is capable of - that particular engine IIRC could only pull 15-16 at most if any amount of throttle was applied, but really as long as vacuum was above 12 the power valves would stay shut and fairly little fuel was being used. Now I kinda wanna know what a typical SEFI 302 runs at when babied...The ones who accomplish true greatness, are the foolish who keep pressing onward.
If I ever build a v8 for fuel economy i'll put a shotgun in my mouth and pull the trigger with my toe. That said, a decently-built, mild small block should be able to attain reasonable mileage. Not stupid prius mileage, but over 20 is not unreasonable. Mod motors are notably better on gas than the small blocks though, that is for sure.
^^^This.
At gas stations people always say things like "Nice car!" which are then followed up with "What kind of MPG's does it get?" I keep track for my own records but I've started telling people things along the lines of, "I don't know, I just put gas in it when it's empty." or "Life is too short to drive boring cars."
I think mod motors are a tad better due to less displacement, more power and better aerodynamics when compared to boxes. If anyone has ever put one in a box I'd be interested to hear about their MPG's and I'd wager their MPG's are significantly less in the box.1985 LTD Crown Victoria - SOLD
I want to put a 3.7L V6 in a box (that 300HP job from the moostang/F150) or an ecoboost and see how that would do. Would probably need to cut some coils off the front springs though.
I think mod motors are a tad better due to less displacement, more power and better aerodynamics when compared to boxes. If anyone has ever put one in a box I'd be interested to hear about their MPG's and I'd wager their MPG's are significantly less in the box.86 Lincoln Town Car (Galactica).
I am following this resurrected thread with great interest. A build with mpg and power is what I am working towards. I know the two are usually opposed to one another but I am trying to figure how to get decent HP/torque and still get very good economy. By decent I think at least 250+hp and 25mph highway would be good target. I was getting 22 to 23 highway taking it easy. (63/64 in a 55) (71/72 in a 65).
The idea of a supercharger is very appealing it would most assuredly get more than 250hp. I don't know what happens with a supercharger and an economy cam when you ask the car to fly. Not saying I would put in a strict economy cam in the car but I am wondering if that combo would totally fubar it up or would it juice up the top end where a lower end power cam is usually crap.
Understand I am gathering data. Thus far I think, 302, cast crank, flat/dished forged pistons with molly rings, gt40 or gt40P heads, balanced rotating assembly & frp headers car already has 2.25" duals. Don't have a cam choice or know supercharged or just explorer intake. I have no plans to dump the AOD at this point, maybe someday but this is more than enough for now.
I think this will probably happen in my dd that I want to last a long time, maybe the rest of my driving life. So it needs to be done right. I want effortless cruising, and hill climbing along with some Yee-ha action from time to time. I know "you can't always get what you want, but if you try sometimes..."Last edited by jaywish; 09-15-2015, 08:34 PM.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
I did say I would like to have the Yee-haw on demand.
To me a steady speed where I regularly get passed by some other drivers to be taking it easy. I am not talking about hyper-mileing here just nice easy cruising. Watching the traffic ahead and behind, planning your moves including passing slower traffic without abrupt speed changes which you need to think about if you keep right except to pass. Not slowing more than a bit for hills and not getting into passing gear unless entering the highway or you need it to get out of some crappy situation which you couldn't plan your way out of.
Of course it is always god for the car to clean the carbon out from time to time (cough, cough).Last edited by jaywish; 09-15-2015, 09:18 PM.03 Marauder DPB, HS, 6disk, Organizer Mods> LED's in & Out, M&Z rear control arms, Oil deflector, U-Haul Trans Pan, Blue Fuzzy Dice
