Oil Filters
    FL-1 or NAPA Gold, WIX. They are all good.
      I use FL-400s on my Vulcan Taurus. The fitment for the grand marquis is the FL-802s on the 4.6L. Will an FL-1A fit? I have seen to many Frams and super techs cut open to use them.
      Sent from my DROID RAZR HD using Tapatalk
        I've found FL-1A's are too long for the 4.6's. Steering parts get in the way on turns and would probably puncture the filter - not a good thing!!
          I think the thread is also different between the 1A and 802s
            May very well be. My Dad had the 4.6 and my '95 also and never tried a FL-1A.
              Motorcraft FL-1A or Purolator L30001 is all I ever used in 5.0s, and Motorcraft FL-820S or Purolator L24651 for my 4.6.
              Matt
              Deep Jewel Green/Mocha 1993 Grand Marquis LS
              Dual exhaust w/ Thrush Welded mufflers, 17x8 bullits, KYB shocks, Air Lift springs, Draw Tite Class II trailer hitch, and new valve seals @ 116,000 mi.
                I have had good luck with Fram PH-8A filters for years now. Getting harder to find a filter for a 5.0 these days around here though, stores don't stock as much of them as there isn't so many older vehicles on the road here anymore. Oil boom economy got everyone drove to highfalutin lifestyles with new cars, bigger houses, cocaine and such.
                Summer car-> 1988 Lincoln Town Car, triple blue, 335,xxx km. New HO 5.0 in and running. Bought 2006/08/22. June 2017 PotM!
                  I've lost 10psi with a Fram filter. The ones I've seen cut open explain the loss.
                  Junk if you ask me.
                    stay away from fram there junk , im sure my holey underwear filters better then them. you cant go wrong with wix ,napa gold, o riellys micro guards ( both made by wix ) or motorcraft, and puralotor pure one. i only use motorcraft or wix on mine.
                    sigpicTHE H.I.D MASTER
                    87 mercury grand marquis
                    88 crown vic lx
                    89 mercury colony park ls (sold)
                    89 mercury grand marquis (sold)
                    00 ford crown vic lx hpp
                    03 mercury marauder aka punisher (sold )
                      or if you want buy one of each and cut them in half and see for yourself what your getting. ive cut a good amount of filter apart new and used. and was shocked with some that i thought were good or premium filters
                      88 crown vic lx
                        As my car nears 425,000 miles, I've always used Frams, mostly Fram Toughguards.
                        Truly,
                        Robert Bernardo
                          Anyone ever seen this?
                          Not exactly scientific, but an interesting read, nonetheless.
                          Nick
                          Past: 1967 Continental convertible, 1987 TC Cartier, 1996 TC DAE & Signature, 2002 LS V8, 2006 Zephyr, 2010 MKZ AWD, and many more.....
                          Current: 2010 F-150 Platinum Supercrew 4x4
                          Wanted: 1967 or 1969 Contnential sedan
                          Only in my dreams: A Continental Mark II
                            I have been using these lately. They have all the best features from what I can see.
                            http://www.fram.com/oil-filters/fram...-filter.aspx#1
                            http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1
                            I use the filter in conjunction with Mobil 1 Synthetic Extended performance oil. Buy at Wallmart. The filters and oil are both rated for 1 year or 15,000 miles. I normally never come close to that annual mileage in any car I maintain. Thus my cost for a DIY oil change is about $40 but I only have to do it once a year in April.
                              I've been using Motorcraft FL-1A's on my CV. If they're out of stock at the time of the oil change, I'll usually just grab whatever else is on the shelf that's compatible.
                                The Motorcraft filters are some of the best on the market if you're driving a Ford product. Great weight, built very well too. Very inexpensive! Just look down inside your oil filters when comparing them. If you still want the grip and don't like using Fram, go with Purolator Gold filters.
                                Avoid STP or any other off brand, like SuperTech.
                                I personally use Autolites (de-badged Fram filter without the grip) on my daily driver. Only $2.69 at my parts store. My daily is now an '89 Park Avenue.
